Comelit módulo de abertura de porta
Pfaleiro1975
Mensagem por Pfaleiro1975 »
Boa tarde amigos, alguém tem o manual para alterar o código de abertura de porta da comelit art° 3127/i não consigo encontrar em lado nenhum.. obrigado
Re: Comelit módulo de abertura de porta
Vê se te consegues safar com este:
comelit.pdf
(915.19 KiB) Transferido 250 vezes
Pfaleiro1975
não dá.
Pfaleiro1975
Installation Instructions
for Comelit keypad
Requires two wires to feed 12v
from systemtransformer
12v Out
PROGRAMMING
Programming operation will abort if after a delay of approx. 40 secs between pressing one button and the next): Therefore the procedure should only be
started once the operator knows the operations to be carried out.
Programming of the supercode is the first operation to be performed. Do not forget this number.
1) Connect power to the keypad.
2) Make the bridge between PGM and the negative.
3) Check that the red LED is on.
4) Key in the supercode (1 to 8 repeatable digits).
5) Press button "E" on the keypad to memorise the code entered.
6) Remove the bridge.
to insert supercode 12345, proceed as follows:
apply power supply; make the bridge; key in the following: 12345 E; remove bridge.
In case of an error during programming, press the “key” button to cancel the operation being carried out. Always remember to press "E" after each
operation
Initial programming of relay codes
In order to proceed with programming of relay codes it is necessary to know the supercode. During programming, the red LED on the keypad will be on. In
case of an error the LED will turn off after a brief flashing, so programming must be started again from the beginning.
1) Key in "0" "E" (start of programming control).
2) Make sure the red LED is on.
3) Key in the supercode, followed by “E”
4) Key in the identification number of the relay (1 or 2) followed by "E".
5) Key in the operation mode (0-90 see below), then "E".
6) Key in the new code to be entered, followed by "E".
7) Check that the LED has turned off.
to insert code 55127 for relay 1, giving a two second contact (suitable for most gate systems), key in the following:
0 E start of programming;12345E supercode (as entered above); 1E identification of relay 1;2 E (2 second contact);
55127E new code
Keyingin55127Ewill nowoperaterelay1
Procedure for insertion of the Supercode (this code does NOT operate the relays)
E.g.:
Procedure for initial programming of relay codes
E.g.:
OPERATIONMODE - At point 5 above thenumber 1-90setsthe number of seconds that therelay is switched.
