I have residential premises in Portugal and a Daikin Air Source Heat Pump for hot water & underfloor heating. It has always seemed expensive to run so I thought I'd install an energy meter to monitor consumption.
I installed an efergy meter http://efergy.com/eu/energy-monitors/on ... ehub3phase
This highlighted the fact that the Daikin Heat Pump was apparently consuming around 500 Watts on standby! So, underfloor heating turned off, hot water turned off, no pump running it was showing a continual consumption of around 500W, 24 hours a day, 7 days a week.
I have an additional problem with an Ikea induction hob that apparently takes 150 Watts on standby. There is a known issue with this particular hob that the power factor on standby is very bad.
The power used as shown by the Efergy meter correlates with the charges made by EDP - extremely high!
EDP tell me that they charge for actual power used (KWh) not apparent power (KVA). But, if my understanding is correct the Efergy meter is showing KVA - so I suspect EDP actually are charging me for apparent power.
So, do EDP ignore poor power factor for residential premises?
Is 500W on standby the right figure for a heat pump, is it just poor power factor, is there another reason?
Any comments very welcome (even in Portuguese
Many thanks
